With tweezers, gently remove the large con board tab.
Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
Peel off the rubber grips to access the screw holes.
Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
Remove the back board and set it aside.
Pull apart the back plastic panel.
Recommended tool for this would be the metal spudger, but not required.
Once the back panel is off, you will have access to the motherboard.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
