メインコンテンツにスキップ
DJI Phantom 3 Advanced Landing Gear Replacement
必要な工具と部品
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: 手順 1、 2の画像 1 DJI Phantom 3 Advanced Landing Gear Replacement, Battery: 手順 1、 2の画像 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: 手順 2、 2の画像 1 DJI Phantom 3 Advanced Landing Gear Replacement: 手順 2、 2の画像 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 手順 3、 3の画像 1 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 手順 3、 3の画像 2 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 手順 3、 3の画像 3
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: 手順 4、 3の画像 1 DJI Phantom 3 Advanced Landing Gear Replacement: 手順 4、 3の画像 2 DJI Phantom 3 Advanced Landing Gear Replacement: 手順 4、 3の画像 3
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: 手順 5、 3の画像 1 DJI Phantom 3 Advanced Landing Gear Replacement: 手順 5、 3の画像 2 DJI Phantom 3 Advanced Landing Gear Replacement: 手順 5、 3の画像 3
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: 手順 6、 3の画像 1 DJI Phantom 3 Advanced Landing Gear Replacement: 手順 6、 3の画像 2 DJI Phantom 3 Advanced Landing Gear Replacement: 手順 6、 3の画像 3
    • Feed the wire and attached plastic through the hole in the landing gear.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Quinn Tirpak
メンバー登録日: 10/06/16
319 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S10G2
3 メンバー
12のガイドは作成済み
コメント 1 件
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 23
今までの合計 3,850
