メインコンテンツにスキップ
DJI Phantom 3 Advanced Cover Replacement
必要な工具と部品
  1. DJI Phantom 3 Advanced Cover Replacement, Battery: 手順 1、 2の画像 1 DJI Phantom 3 Advanced Cover Replacement, Battery: 手順 1、 2の画像 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Cover Replacement: 手順 2、 2の画像 1 DJI Phantom 3 Advanced Cover Replacement: 手順 2、 2の画像 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Cover Replacement, Cover: 手順 3、 1の画像 1
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced Cover Replacement: 手順 4、 1の画像 1
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced Cover Replacement: 手順 5、 2の画像 1 DJI Phantom 3 Advanced Cover Replacement: 手順 5、 2の画像 2
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced Cover Replacement: 手順 6、 2の画像 1 DJI Phantom 3 Advanced Cover Replacement: 手順 6、 2の画像 2
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced Cover Replacement: 手順 7、 3の画像 1 DJI Phantom 3 Advanced Cover Replacement: 手順 7、 3の画像 2 DJI Phantom 3 Advanced Cover Replacement: 手順 7、 3の画像 3
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced Cover Replacement: 手順 8、 3の画像 1 DJI Phantom 3 Advanced Cover Replacement: 手順 8、 3の画像 2 DJI Phantom 3 Advanced Cover Replacement: 手順 8、 3の画像 3
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
終わりに
11 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Robert Comstock
メンバー登録日: 10/06/16
433 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S10G2
3 メンバー
12のガイドは作成済み
3件のガイドコメント
Great Job Robert! Even the “Phantom Pilots Forum” had no recent recommendations for a disassembly manual, as DJI likes to “Fixit” themselves!
Michael Steinbrecher - 返信
Excellent detailed instructions. Having pictures on procedure makes it idiot proof.
Bolo - 返信
Does this also include the phantom 3 professional too? My understanding is that the only differences between them is the battery charger and the pro is 4k recording vs 1080p.
John D - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 39
今までの合計 5,042
