はじめに
Replace or upgrade your Phantom motors. This guide requires soldering. Each motor's direction is determined by the order of its leads on the ESC, so during the replacement, be sure to match the original order. Motors on opposite arms will have the same direction, so check the opposite arm for a wiring reference.
If you're ordering a replacement, be sure to get the right thread direction for your motor, or the propellor collet will loosen during flight.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
  1. Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it. The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other. The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. Determine if the propellor is clockwise or counter-clockwise rotating.
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise. Remove the propellor. Remove the propellor.
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise. Remove the propellor. Remove the propellor.
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
  5. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  6. Remove the following screws from the underside of the Phantom: Twelve 2.0 mm hex bolts
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  7. Gently lift up the top shell case. Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  8. The GPS cable molex connector is located on the backside of the mainboard, near the battery opening. Pull the GPS connector straight up out of its socket. Lift the top shell case up and remove it from the body of the Phantom.
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
  9. Desolder all three motor wires. When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
    • Desolder all three motor wires.
    • When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
    • The motor spin direction is dependent on the order of the wires, and may not match this image exactly. If you forgot the order, check the arm directly opposite for reference.
  10. Remove the four 2mm hex motor bolts.
    • Remove the four 2mm hex motor bolts.
  11. Remove the motor from the motor mount. Remove the motor from the motor mount.
    • Remove the motor from the motor mount.
まとめ
ある他の人がこのガイドを完成しました。
David Hoyt
メンバー登録日: 2010年04月09日
3,667 ポイント
43のガイドは作成済み
チーム
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G89
4 メンバー
52のガイドは作成済み
統計データを表示:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 30
今までの合計 4,067
