メインコンテンツにスキップ
DJI Mavic Pro Upper Shell Replacement
必要な工具と部品
  1. DJI Mavic Pro Upper Shell Replacement, Battery: 手順 1、 3の画像 1 DJI Mavic Pro Upper Shell Replacement, Battery: 手順 1、 3の画像 2 DJI Mavic Pro Upper Shell Replacement, Battery: 手順 1、 3の画像 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Upper Shell Replacement, Upper Shell: 手順 2、 1の画像 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Upper Shell Replacement: 手順 3、 1の画像 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    the author forgot to mention to remove also the two screws right next to the gimbal. in this picture, they are already removed. without removing these, you cannot open the drone!!
    Joris Ott - 返信
    also, the screws above in the red circles are not the same as the ones in step 2 and 5! They are shorter! I don’t know how long but not 5mm!
    Joris Ott - 返信
    Yes, please add those screws - almost broke the top case ;-(
    xyz40 - 返信
    Screws thinner too.
    Lee Day - 返信
  4. DJI Mavic Pro Upper Shell Replacement: 手順 4、 1の画像 1
    • Remove the two small panel pieces near the gimbal case with the tweezers.
    BEWARE! The two screws under the covers are not mentioned in step four to be removed, but they show that they have been removed in step five.
    Patrick Madden - 返信
    Step five should read- Remove the SIX 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
    Patrick Madden - 返信
  5. DJI Mavic Pro Upper Shell Replacement: 手順 5、 1の画像 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
    You need to remove the 2 screws (as the picture shows) that are adjacent to each side of the gimbal (below the screws circled in the picture. This also connect to the top shell and could cause an issue!
    ellfa1 - 返信
    You might notice that there are two crosshead screws with larger heads (top two circled in image). You do NOT need to touch these as they are not part of the gimbal assembly.
    james.collins1905 - 返信
    Agree with @elfa1 - do not remove the top two screws, or you will put unnecessary strain on the plastic while moving arms. No need for that at all.
    demanufacturer - 返信
  6. DJI Mavic Pro Upper Shell Replacement: 手順 6、 1の画像 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
    using pry tool is not necessary - once all top shell screws are removed you should be able to take the top shell off with your hand.
    KopaZ Maymay - 返信
    Sorry “KopaZ Maymay”, aber der Plastiköffner ist “sowas von erforderlich”, weil man sonst leider die beiden Plastiknasen in der Front riskiert.
    Orbiter - 返信
    Zudem fehlt hier die Angabe der genauen Lage von beiden vorderen Nasen:
    Sie befinden sich von der Mitte aus gemessen jeweils 9mm nach links und rechts. Der obere Gehäuseteil wird von zwei 5mm breiten Bügeln gehalten, die unter die horizontal nach innen zeigenden Nasen vom unteren Gehäuseteil greifen.
    Orbiter - 返信
    Sorry “KopaZ Maymay”, but the plastic opener is “so necessary” because otherwise you unfortunately risk the two plastic noses in the front.
    In addition, the exact position of both front noses is missing in the description:
    They are measured 9mm from the center to the left and right. The upper part of the housing is held by two 5mm wide brackets that grip under the noses pointing horizontally inwards from the lower part of the housing.
    Orbiter - 返信
    Hi, is it a simple replacement. Ie you do not have to reprogram? Thanks
    farkin joker - 返信
  7. DJI Mavic Pro Upper Shell Replacement: 手順 7、 1の画像 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
    Hello there, can anyone tell me, please, what type of connector is this? I ruined mine and i like to fixit.
    Ene Alexandru - 返信
終わりに
6 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Mondona Behroozian
メンバー登録日: 10/08/18
1,552 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G3
4 メンバー
14のガイドは作成済み
2 件のコメント
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - 返信
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 44
今までの合計 5,158
