メインコンテンツにスキップ
DJI Mavic Pro Upper Shell Replacement
必要な工具と部品
  1. DJI Mavic Pro Upper Shell Replacement, Battery: 手順 1、 3の画像 1 DJI Mavic Pro Upper Shell Replacement, Battery: 手順 1、 3の画像 2 DJI Mavic Pro Upper Shell Replacement, Battery: 手順 1、 3の画像 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Upper Shell Replacement, Upper Shell: 手順 2、 1の画像 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Upper Shell Replacement: 手順 3、 1の画像 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Upper Shell Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Upper Shell Replacement: 手順 5、 1の画像 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Upper Shell Replacement: 手順 6、 1の画像 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Upper Shell Replacement: 手順 7、 1の画像 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
終わりに
6 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Mondona Behroozian
メンバー登録日: 10/08/18
1,567 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G3
4 メンバー
14のガイドは作成済み
2 件のコメント
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - 返信
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 55
今までの合計 5,323
