メインコンテンツにスキップ
DJI Mavic Pro GPS Module Replacement
必要な工具と部品
  1. DJI Mavic Pro GPS Module Replacement, Battery: 手順 1、 3の画像 1 DJI Mavic Pro GPS Module Replacement, Battery: 手順 1、 3の画像 2 DJI Mavic Pro GPS Module Replacement, Battery: 手順 1、 3の画像 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro GPS Module Replacement, Upper Shell: 手順 2、 1の画像 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro GPS Module Replacement: 手順 3、 1の画像 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro GPS Module Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro GPS Module Replacement: 手順 5、 1の画像 1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro GPS Module Replacement: 手順 6、 1の画像 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro GPS Module Replacement: 手順 7、 1の画像 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro GPS Module Replacement, GPS Module: 手順 8、 1の画像 1
    • Flip the upper shell over so the metallic plate is facing up.
    • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
    • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
  9. DJI Mavic Pro GPS Module Replacement: 手順 9、 1の画像 1
    • Pry the metallic plate up from the upper shell by using a nylon spudger.
    • Remove the metallic plate from the upper shell by lifting the plate up and out.
    • You may hear a popping sound when prying the metallic plate, but no damage will occur.
  10. DJI Mavic Pro GPS Module Replacement: 手順 10、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the GPS Module from the upper shell.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kyle Kelser
メンバー登録日: 10/08/18
598 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G3
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 86
今までの合計 8,850
