メインコンテンツにスキップ
DJI Mavic Pro Controller Micro USB Port Replacement
必要な工具と部品
  1. DJI Mavic Pro Controller Micro USB Port Replacement, Identify broken part: 手順 1、 1の画像 1
    • It's easy to put the micro USB in the wrong way around (turned 180 degrees) this will break your pins and makes the controller not able to charge anymore. Check if the inside of your port is all good
  2. DJI Mavic Pro Controller Micro USB Port Replacement, Get the replacement part: 手順 2、 2の画像 1 DJI Mavic Pro Controller Micro USB Port Replacement, Get the replacement part: 手順 2、 2の画像 2
    • get the replacement part for your controller where the Micro Usb is connected to
  3. DJI Mavic Pro Controller Micro USB Port Replacement, Get started: 手順 3、 1の画像 1
    • Get your tools, controller and part in place to get started
  4. DJI Mavic Pro Controller Micro USB Port Replacement, Remove Joystick: 手順 4、 1の画像 1
    • First remove the joystick. You can just pull this out. In my case I already lost it 2 years ago. Easy!
  5. DJI Mavic Pro Controller Micro USB Port Replacement, Unscrew 2 bottom caps: 手順 5、 2の画像 1 DJI Mavic Pro Controller Micro USB Port Replacement, Unscrew 2 bottom caps: 手順 5、 2の画像 2
    • Unscrew the two screws on the bottom using a torx 6
  6. DJI Mavic Pro Controller Micro USB Port Replacement, Open the cover: 手順 6、 1の画像 1
    • This was the most complex step. Once you remove the 2 screws from the previous step you can open up the bottom. This is a tough piece of plastic clicked into the sides. It required some fiddling and squeezing. It looks like you will break the plastic. But you won't. Plastic is precious you know
  7. DJI Mavic Pro Controller Micro USB Port Replacement, Remove the front panel: 手順 7、 3の画像 1 DJI Mavic Pro Controller Micro USB Port Replacement, Remove the front panel: 手順 7、 3の画像 2 DJI Mavic Pro Controller Micro USB Port Replacement, Remove the front panel: 手順 7、 3の画像 3
    • First remove the 2 phillips screws on at the top corners. There are 2 places where the front panels locks on the controller. (those big round things) Just pull it of there and you can open up the controller and remove the panel
  8. DJI Mavic Pro Controller Micro USB Port Replacement, Open the controller: 手順 8、 2の画像 1 DJI Mavic Pro Controller Micro USB Port Replacement, Open the controller: 手順 8、 2の画像 2
    • Now the controller is open, you can see the part you need to replace, just a few steps away
  9. DJI Mavic Pro Controller Micro USB Port Replacement, Remove the keyboard cable: 手順 9、 1の画像 1
    • open up the tiny lever and you can remove the data cable of the keyboard
  10. DJI Mavic Pro Controller Micro USB Port Replacement, remove final 2 screw: 手順 10、 2の画像 1 DJI Mavic Pro Controller Micro USB Port Replacement, remove final 2 screw: 手順 10、 2の画像 2
    • There are.2 screws that connect the part you want to replace. Unscrew and you can remove it
  11. DJI Mavic Pro Controller Micro USB Port Replacement, Replace the part and check: 手順 11、 1の画像 1
    • You can now replace the part, but before we put everything back together make sure it works (charges! :)
  12. DJI Mavic Pro Controller Micro USB Port Replacement, Future Upgrade: 手順 12、 1の画像 1
    • My part broke because I put the cable in wrong way around, apparently this is a common problem from this controller. Makes me wonder why it usually does not go wrong. Anyway, to prevent this in the future i've marked how the Micro USB cable should go in. Flat part down!
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Dave Hakkens
メンバー登録日: 01/03/16
1,024 ポイント
3のガイドは作成済み
9 件のコメント
Thank you for sharing your experience and knowledge. :-)
Fernando Kojin - 返信
How and where do you get this replacement part from DJI ?
I have the exact same issue
Romain Rosset - 返信
I see you didn’t respond back to Romain and I have the same question now, after reviewing your incredible detailed example of replacement. Same reason, obviously, I put the connector in upside down and broke it… thank you, hope you respond soon
Pops Eagles - 返信
Got it somewhere from ebay
Dave Hakkens -
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 36
今までの合計 6,366
