メインコンテンツにスキップ
DJI Mavic Mini GPS Replacement
必要な工具と部品
  1. DJI Mavic Mini GPS Replacement, Battery: 手順 1、 2の画像 1 DJI Mavic Mini GPS Replacement, Battery: 手順 1、 2の画像 2
    • Orient the DJI Mavic Mini so that the camera faces away.
    • Use your finger to depress the lip on the panel until the lid becomes ajar.
    • Flip the panel up to expose the battery module.
  2. DJI Mavic Mini GPS Replacement: 手順 2、 2の画像 1 DJI Mavic Mini GPS Replacement: 手順 2、 2の画像 2
    • Depress the locking mechanism on the battery module to release the lock.
    • Pull the battery straight out of the casing.
  3. DJI Mavic Mini GPS Replacement: 手順 3、 2の画像 1 DJI Mavic Mini GPS Replacement: 手順 3、 2の画像 2
    • Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
    • Check the pin receptacles on the battery module for blockages.
    • Insert a new battery into the casing. Ensure that all connections are clean, unobstructed, and straight.
  4. DJI Mavic Mini GPS Replacement, GPS: 手順 4、 2の画像 1 DJI Mavic Mini GPS Replacement, GPS: 手順 4、 2の画像 2
    • Put your fingers against edge of the top case and begin undoing the connections at the edges first, then proceed to pry it open.
    • Alternatively, you may insert the iFixit opening tool between the top and bottom case first, and work your way around the perimeter to detach the top case.
  5. DJI Mavic Mini GPS Replacement: 手順 5、 1の画像 1
    • With the internals exposed, locate the GPS board; this is the middle board component with a colored square located near the middle of the drone.
  6. DJI Mavic Mini GPS Replacement: 手順 6、 3の画像 1 DJI Mavic Mini GPS Replacement: 手順 6、 3の画像 2 DJI Mavic Mini GPS Replacement: 手順 6、 3の画像 3
    • Remove the three 1.0 mm screws that form a triangle around the GPS board using the JIS #000 screwdriver.
    • Flip the GPS module over gently. Be mindful that it is attached to the device with a connector still.
  7. DJI Mavic Mini GPS Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use the ESD Safe Tweezers Blunt Nose tool to break apart the superglue connecting the cable to the GPS.
    • Repeat this for the superglue on the other side.
    • Detach the press-fit connecter from the GPS.
  8. DJI Mavic Mini GPS Replacement: 手順 8、 1の画像 1
    • Remove the GPS from the drone.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Edward Ng
メンバー登録日: 02/22/22
175 ポイント
1ガイドが承認済み
チーム
Clemson, Team 1-2, Hunter Spring 2022 Clemson, Team 1-2, Hunter Spring 2022人のメンバー
CLEM-HUNTER-S22S1G2
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 16
過去 30 日: 57
今までの合計 2,212
