メインコンテンツにスキップ
DBPOWER RD-810 Speaker Replacement
必要な工具と部品
  1. DBPOWER RD-810 Speaker Replacement, Top Cover: 手順 1、 2の画像 1 DBPOWER RD-810 Speaker Replacement, Top Cover: 手順 1、 2の画像 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Speaker Replacement: 手順 2、 1の画像 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Speaker Replacement, Motherboard and LED Bulb: 手順 3、 3の画像 1 DBPOWER RD-810 Speaker Replacement, Motherboard and LED Bulb: 手順 3、 3の画像 2 DBPOWER RD-810 Speaker Replacement, Motherboard and LED Bulb: 手順 3、 3の画像 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Speaker Replacement: 手順 4、 3の画像 1 DBPOWER RD-810 Speaker Replacement: 手順 4、 3の画像 2 DBPOWER RD-810 Speaker Replacement: 手順 4、 3の画像 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Speaker Replacement: 手順 5、 3の画像 1 DBPOWER RD-810 Speaker Replacement: 手順 5、 3の画像 2 DBPOWER RD-810 Speaker Replacement: 手順 5、 3の画像 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Speaker Replacement, Power Supply Circuit: 手順 6、 3の画像 1 DBPOWER RD-810 Speaker Replacement, Power Supply Circuit: 手順 6、 3の画像 2 DBPOWER RD-810 Speaker Replacement, Power Supply Circuit: 手順 6、 3の画像 3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Speaker Replacement: 手順 7、 2の画像 1 DBPOWER RD-810 Speaker Replacement: 手順 7、 2の画像 2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Speaker Replacement, Speaker: 手順 8、 2の画像 1 DBPOWER RD-810 Speaker Replacement, Speaker: 手順 8、 2の画像 2
    • Pull gently on the speaker to break the glue bond, then lift the speaker out of the way.
    • Do not pull on the wires while trying to break the glue bond.
終わりに
作成者
1人の作成者と共同作成されました。
John Russell
メンバー登録日: 02/14/18
914 ポイント
9のガイドは作成済み
チーム
USF Tampa, Team S5-G3, Eyestone Spring 2018 USF Tampa, Team S5-G3, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S5G3
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 321
