メインコンテンツにスキップ
DBPOWER RD-810 Power Supply Switch Replacement
必要な工具と部品
  1. DBPOWER RD-810 Power Supply Switch Replacement, Top Cover: 手順 1、 2の画像 1 DBPOWER RD-810 Power Supply Switch Replacement, Top Cover: 手順 1、 2の画像 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Power Supply Switch Replacement: 手順 2、 1の画像 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: 手順 3、 3の画像 1 DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: 手順 3、 3の画像 2 DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: 手順 3、 3の画像 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Power Supply Switch Replacement: 手順 4、 3の画像 1 DBPOWER RD-810 Power Supply Switch Replacement: 手順 4、 3の画像 2 DBPOWER RD-810 Power Supply Switch Replacement: 手順 4、 3の画像 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Power Supply Switch Replacement: 手順 5、 3の画像 1 DBPOWER RD-810 Power Supply Switch Replacement: 手順 5、 3の画像 2 DBPOWER RD-810 Power Supply Switch Replacement: 手順 5、 3の画像 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: 手順 6、 3の画像 1 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: 手順 6、 3の画像 2 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: 手順 6、 3の画像 3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Power Supply Switch Replacement: 手順 7、 2の画像 1 DBPOWER RD-810 Power Supply Switch Replacement: 手順 7、 2の画像 2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: 手順 8、 3の画像 1 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: 手順 8、 3の画像 2 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: 手順 8、 3の画像 3
    • Using the small plastic splunger, press in on the two latches on the sides of the power supply switch, then push it out of the case.
終わりに
作成者
1人の作成者と共同作成されました。
John Russell
メンバー登録日: 02/14/18
914 ポイント
9のガイドは作成済み
チーム
USF Tampa, Team S5-G3, Eyestone Spring 2018 USF Tampa, Team S5-G3, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S5G3
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 169
