はじめに
The imager creates the picture that the projector displays. Because any dust or dirt stuck to the imager could cause distortions, it is important to keep the imager clean. If the image is not being displayed or is blurry or distorted, the imager may need to be cleaned or replaced.
必要な工具と部品
Place the projector upside down to access the screws on the bottom.
Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
Remove the three 6mm PH2 phillips head screws.
Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
2 の人々がこのガイドを完成させました。
