はじめに
I phoned D-Link tech support several times, and they eventually concluded my device was broken, but I got it fixed.
My D-Link dhp w306av would do nothing but blink it's blue (WPS/ENY) LED. None of the support people could fix it with any kind of reset. This is what I managed to do.
  1. (With router unpluged, and no ethernet cable attched) Turn the router on (push in the power button on the side) remember it's not plugged into the wall yet.
    • (With router unpluged, and no ethernet cable attched) Turn the router on (push in the power button on the side) remember it's not plugged into the wall yet.
  2. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  3. Take a pin or micro screwdriver and push in and hold the reset button.
    • Take a pin or micro screwdriver and push in and hold the reset button.
    • Still holding the reset button plug the router into a power outlet.
    • Keep holding down the reset button for at least 15 seconds.
    • If you have the same luck I did your green lights on the side will start to cycle and light up.
    • Now you can go back to your quick install guide that came with the router and set it up again.
まとめ
hope it works for you
4 の人々がこのガイドを完成させました。
alan
メンバー登録日: 2013年08月23日
212 ポイント
1ガイドが承認済み
コメントを追加する
統計データを表示:
過去 24時間: 3
過去 7 日: 24
過去 30 日: 101
今までの合計 4,657
