メインコンテンツにスキップ
はじめに
If your camera is failing to move in a certain direction one of the two motors inside may be malfunctioning. If this is the case the motor will need to be replaced. The replacement process is pretty simple and doesn't need many tools. It is important to keep track of the small screws, they are easily lost.
パーツ
パーツは指定されていません。
  1. D-Link DCS-5222L Motor Replacement, Motors: 手順 1、 3の画像 1 D-Link DCS-5222L Motor Replacement, Motors: 手順 1、 3の画像 2 D-Link DCS-5222L Motor Replacement, Motors: 手順 1、 3の画像 3
    • Remove the four rubber feet on the bottom of the camera with tweezers.
    • Remove the four screws using a Phillips #1 screwdriver.
    • Remove the lower piece of the camera body.
  2. D-Link DCS-5222L Motor Replacement: 手順 2、 2の画像 1 D-Link DCS-5222L Motor Replacement: 手順 2、 2の画像 2
    • Remove the motherboard and bottom of the camera body.
    • Disconnect the five cables from the motherboard using tweezers.
  3. D-Link DCS-5222L Motor Replacement: 手順 3、 2の画像 1 D-Link DCS-5222L Motor Replacement: 手順 3、 2の画像 2
    • Use a #1 Phillips screwdriver to remove the two 7mm screws holding the motor in place.
  4. D-Link DCS-5222L Motor Replacement: 手順 4、 2の画像 1 D-Link DCS-5222L Motor Replacement: 手順 4、 2の画像 2
    • Using your hands, separate the bottom of the body from the upper portion.
  5. D-Link DCS-5222L Motor Replacement: 手順 5、 2の画像 1 D-Link DCS-5222L Motor Replacement: 手順 5、 2の画像 2
    • To remove the top of the camera you must push in the black tabs using the spudger. There are 3 tabs per side.
    • While pushing in the tabs, you can now lift the top black portion of the camera using your hands.
  6. D-Link DCS-5222L Motor Replacement: 手順 6、 2の画像 1 D-Link DCS-5222L Motor Replacement: 手順 6、 2の画像 2
    • With a little wiggle, the camera module will come free from the body.
    • Unscrew the two 7mm screws on the camera using a #1 Phillips screwdriver.
  7. D-Link DCS-5222L Motor Replacement: 手順 7、 2の画像 1 D-Link DCS-5222L Motor Replacement: 手順 7、 2の画像 2
    • Pry apart the camera housing with your fingers to reveal the second motor.
  8. D-Link DCS-5222L Motor Replacement: 手順 8、 1の画像 1
    • Unscrew the two 6mm screws holding the motor in place with a #1 Phillips screwdriver.
終わりに
ある他の人がこのガイドを完成しました。
Jason Munyon
メンバー登録日: 2018年10月30日
268 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S2G5
3 メンバー
10のガイドは作成済み
2 件のコメント
Where can I buy new motor?
Michael Williams - 返信
I do not know, I purchased a “for Parts” camera on e-bay for $15.00 and used the motor from that unit.
Ed Wheelbarger - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 505
