メインコンテンツにスキップ
はじめに
Use this guide to assist with general disassembly or troubleshooting of your braille display.
パーツ
パーツは指定されていません。
  1. Remove the four bottom screws with a Phillips #00 screwdriver. Remove the four bottom screws with a Phillips #00 screwdriver.
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset.
    • Remove the plastic cover, paper and chipset.
  3. Remove the two screws with a Phillips #00 screwdriver on the logic board. take out the main circuit like show in the picture take out the main circuit like show in the picture
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  4. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver.
    • Remove the four screws with a Phillips #00 screwdriver.
  5. Remove the connector delicately. Remove the connector delicately. Remove the connector delicately.
    • Remove the connector delicately.
  6. when you put it back together make sure mechanical cells are connected correctly when you put it back together make sure mechanical cells are connected correctly
    • when you put it back together make sure mechanical cells are connected correctly
まとめ
Sisyphe
メンバー登録日: 2013年07月29日
332 ポイント
2のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 548
