メインコンテンツにスキップ
iPhone 4 Battery disconnection
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. iPhone 4  Battery disconnection, Rear Panel: 手順 1、 2の画像 1 iPhone 4  Battery disconnection, Rear Panel: 手順 1、 2の画像 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
    • Be sure the driver is well seated when removing Pentalobe screws, they are very easy to strip.
  2. iPhone 4  Battery disconnection: 手順 2、 2の画像 1 iPhone 4  Battery disconnection: 手順 2、 2の画像 2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4  Battery disconnection: 手順 3、 1の画像 1
    • Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
    • If you are installing a new rear panel, be sure to remove the plastic protective sticker from the inside of the camera lens and the sticker from the large black area near the lens.
  4. iPhone 4  Battery disconnection, Battery disconnection: 手順 4、 1の画像 1
    • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
    • Simply place the screwdriver a few minutes on a magnet to magnetize. It will then much easier to remove the screws and even to put them back.
  5. iPhone 4  Battery disconnection: 手順 5、 1の画像 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
    • The oils on your fingers have the potential to cause wireless interference issues. Be careful to not use your fingers.
終わりに
56 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
revher
メンバー登録日: 08/17/13
4,076 ポイント
2のガイドは作成済み
コメント 1 件
thank you for battery disconnect
ovikumarbarman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 19,078
