メインコンテンツにスキップ
CyberpowerPC Fangbook HX6 Screen Replacement
必要な工具と部品
  1. CyberpowerPC Fangbook HX6 Screen Replacement, Screen: 手順 1、 1の画像 1
    • To replace the screen you will need a screwdriver (a size zero was used in this guide), and a tool that can be used to pry off the screen covering (a spudger was used in this guide).
  2. CyberpowerPC Fangbook HX6 Screen Replacement: 手順 2、 3の画像 1 CyberpowerPC Fangbook HX6 Screen Replacement: 手順 2、 3の画像 2 CyberpowerPC Fangbook HX6 Screen Replacement: 手順 2、 3の画像 3
    • Insert the spudger gently into the seam that connects the front plate to the rest of the device.
    • Move the tool carefully around the screen and apply a small amount of pressure. You are trying to undo several clasps holding the front plate on.
    • Do this on all sides of the face plate except for the bottom. The bottom will have a strip of adhesive you will need to carefully pull off to separate the face plate from the bottom of the screen.
  3. CyberpowerPC Fangbook HX6 Screen Replacement: 手順 3、 2の画像 1 CyberpowerPC Fangbook HX6 Screen Replacement: 手順 3、 2の画像 2
    • Remove the two 4mm silver screws on both sides of the top of the screen.
    • Once you have removed them, gently pull the screen off of the aligning dials (the small plastic pieces to the left of the screws).
  4. CyberpowerPC Fangbook HX6 Screen Replacement: 手順 4、 2の画像 1 CyberpowerPC Fangbook HX6 Screen Replacement: 手順 4、 2の画像 2
    • At this point the only thing keeping the screen attached to the laptop is this small wire and connector shown here.
    • Gently pull the screen out and turn it over so that you can see where the connector is attached.
    • Carefully remove it. Once this is done you have successfully removed the screen from your laptop.
終わりに
作成者
2人の作成者と共同で作成されました。
Eric Box
メンバー登録日: 09/12/18
159 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team S1-G4, Bedsole Fall 2018 University of Alabama, Team S1-G4, Bedsole Fall 2018人のメンバー
UA-BEDSOLE-F18S1G4
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 804
