はじめに
If you want to upgrade the RAM in your prebuilt CyberSeriesPC (Model C-Series) so your computer can be faster, use this step-by-step guide to replace your RAM.
A RAM's purpose is to store the short-term data that a PC requires to operate correctly, so having an updated RAM will help optimize your computer.
Here's an article on why having better RAM is important.
Be careful with the electronic parts and RAM because they are delicate and could break.
Before beginning, make sure to power off your computer entirely and disconnect from any external power source. This is critical because if you do not do this, you can harm your computer and even yourself.
必要な工具と部品
Place the computer on a table.
Remove the screws holding the side panel with a screwdriver.
Slide the side panel from right to left to open the computer and see its components.
Place the side panel somewhere else to keep the area clear, and set the computer down on its side, where the open side is up for you to work.
Slide the side panel back onto the computer from the left until it clicks.
Tighten the screws back onto the side panel with the screwdriver.
Before reinserting the power cable and turning the power switch on, insert any other removed wires.
Place the power cable back in its outlet.
Turn the power switch on.
To confirm the RAM sticks are properly working, turn the computer on and let it boot up.
Click on the search button in the lower-left corner of your monitor screen.
Search for "System Information," then click on it.
In the "Find what:" search bar, type "RAM," and press enter.
You will see that your new RAM is installed correctly and working, making it a successful switching of parts!
5 の人々がこのガイドを完成させました。
