メインコンテンツにスキップ
CyberPowerPC RGB 7 Color Motherboard Replacement
必要な工具と部品
  1. CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: 手順 1、 2の画像 1 CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: 手順 1、 2の画像 2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color Motherboard Replacement: 手順 2、 2の画像 1 CyberPowerPC RGB 7 Color Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color Motherboard Replacement: 手順 3、 1の画像 1
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color Motherboard Replacement, LED Backlight: 手順 4、 1の画像 1
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color Motherboard Replacement: 手順 5、 1の画像 1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color Motherboard Replacement: 手順 6、 1の画像 1
    • Carefully remove the LED board, which should now come free from the casing.
  7. CyberPowerPC RGB 7 Color Motherboard Replacement, Motherboard: 手順 7、 1の画像 1
    • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
  8. CyberPowerPC RGB 7 Color Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the motherboard and its attached cable from the plastic casing. The cord should now come free to replace.
終わりに
作成者
4人の作成者と共同で作成されました。
Katherine Von Braunsberg
メンバー登録日: 02/12/18
359 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S15-G2, Boczar Spring 2018 USF Tampa, Team S15-G2, Boczar Spring 2018人のメンバー
USFT-BOCZAR-S18S15G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 385
