メインコンテンツにスキップ
CyberPower UPS Battery Replacement
必要な工具と部品
  1. CyberPower UPS Battery Replacement, Battery: 手順 1、 2の画像 1 CyberPower UPS Battery Replacement, Battery: 手順 1、 2の画像 2
    • Power down the unit by pressing the power button until the display goes black.
    • This is usually about 3 seconds.
    • Unplug the power cord from the wall outlet.
  2. CyberPower UPS Battery Replacement: 手順 2、 3の画像 1 CyberPower UPS Battery Replacement: 手順 2、 3の画像 2 CyberPower UPS Battery Replacement: 手順 2、 3の画像 3
    • Remove the battery plate cover at the bottom of the UPS using a Phillips #1 screwdriver.
    • If the screwdriver is not magnetized, tap on the cover plate to completely remove the screw.
  3. CyberPower UPS Battery Replacement: 手順 3、 2の画像 1 CyberPower UPS Battery Replacement: 手順 3、 2の画像 2
    • Slide the battery cover plate to the left.
    • Grasp the battery plate cover and lift it off the the UPS.
  4. CyberPower UPS Battery Replacement: 手順 4、 3の画像 1 CyberPower UPS Battery Replacement: 手順 4、 3の画像 2 CyberPower UPS Battery Replacement: 手順 4、 3の画像 3
    • Pull out the battery to expose the terminal connectors.
    • Use needlenose pliers to disconnect both battery terminal connectors.
    • Do not pull the connectors by the wires, pull connectors by grabbing the connector itself.
    • With the battery terminal connectors disconnected, slide the battery all the way out.
  5. CyberPower UPS Battery Replacement: 手順 5、 3の画像 1 CyberPower UPS Battery Replacement: 手順 5、 3の画像 2 CyberPower UPS Battery Replacement: 手順 5、 3の画像 3
    • The replacement battery should be a 12 volt, 9 amp-hour, sealed lead acid battery with f2 type connectors.
    • Install the new battery and reconnect the terminals.
  6. CyberPower UPS Battery Replacement: 手順 6、 3の画像 1 CyberPower UPS Battery Replacement: 手順 6、 3の画像 2 CyberPower UPS Battery Replacement: 手順 6、 3の画像 3
    • Insert the screw to secure the battery cover plate.
    • Tighten the screw with a Phillips #1 screwdriver.
  7. CyberPower UPS Battery Replacement: 手順 7、 3の画像 1 CyberPower UPS Battery Replacement: 手順 7、 3の画像 2 CyberPower UPS Battery Replacement: 手順 7、 3の画像 3
    • Plug system into the wall outlet.
    • Press the power button to turn on the unit.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jervon Stuart
メンバー登録日: 10/07/20
169 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S3-G8, Willis Fall 2020 University of Memphis, Team S3-G8, Willis Fall 2020人のメンバー
UM-WILLIS-F20S3G8
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 81
過去 30 日: 333
今までの合計 12,840
