はじめに
Replacing the top panel only involves unscrewing four screws and gently removing the top panel from the rest of the dvd player.
必要な工具と部品
Unplug the DVD player from the wall socket.
Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
ある他の人がこのガイドを完成しました。
