はじめに
Replacing the power supply involves unplugging the white connection cord from the power supply board after the top panel is removed.
必要な工具と部品
Unplug the DVD player from the wall socket.
Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Orient the device to locate the power supply board on the far right corner. Use needle nose pliers to pull the white connector from the power supply board.
Where can i get the new board?
Where can I get a new power supply board?
3 の人々がこのガイドを完成させました。
8 件のコメント
Very powerful
Mine had a bad 2200uf 10v capacitor… I replaced it and the player works fine.
What and where is that located please?
So what capacitor have u replaced ?
I need another power supply board. Mine has 4 blown Capacitors and do not know if any resisters or diodes or small capacitors are bad because I have now testing tools to check them. Just what I see with eyes. Am a retired electronics professional (79) and know what I am doing. Please let me know if I can get a power supply board and the cost. Thank You .
So I guess no response?
I want to use this board as a project power supply. Any idea in the spec for the 12v and 5v as regard to watts/amps?
