メインコンテンツにスキップ
CyberHome CH-DVD 300 Power Supply Replacement
必要な工具と部品
  1. CyberHome CH-DVD 300 Power Supply Replacement, Top Panel: 手順 1、 2の画像 1 CyberHome CH-DVD 300 Power Supply Replacement, Top Panel: 手順 1、 2の画像 2
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Power Supply Replacement: 手順 2、 2の画像 1 CyberHome CH-DVD 300 Power Supply Replacement: 手順 2、 2の画像 2
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: 手順 3、 3の画像 1 CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: 手順 3、 3の画像 2 CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: 手順 3、 3の画像 3
    • Orient the device to locate the power supply board on the far right corner. Use needle nose pliers to pull the white connector from the power supply board.
    • The power supply board is connected directly to the power cord. This is not the same thing as the mother board.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Chris Menezes
メンバー登録日: 04/07/14
642 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 6-5, Forte Spring 2014 Cal Poly, Team 6-5, Forte Spring 2014人のメンバー
CPSU-FORTE-S14S6G5
5 メンバー
5のガイドは作成済み
8 件のコメント
Mine had a bad 2200uf 10v capacitor… I replaced it and the player works fine.
Robert Brackett - 返信
What and where is that located please?
Kealani Rowe -
So what capacitor have u replaced ?
semyonaxelrod -
I need another power supply board. Mine has 4 blown Capacitors and do not know if any resisters or diodes or small capacitors are bad because I have now testing tools to check them. Just what I see with eyes. Am a retired electronics professional (79) and know what I am doing. Please let me know if I can get a power supply board and the cost. Thank You .
Glennie Waters - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 3,973
