必要な工具と部品
Removing the cover: follow these steps to remove the cover from the cabinet: 1. Turn off the system. Disconnect all cables in the back of the cabinet, including the power cords. 2. Examine your cabinet to determine how to remove the cover. Remove the screws that secure the cover to the chassis.
Removal of the cards: Note in which slots each adapter is located; 2. Remove the screw that holds the adapter. 3. Record the positions of all cables that the adapter may have before removing them. 4. Remove the adapter by lifting with equal force at both ends. 5. Write down the positions of all the switches on the card
Removal of the motherboard: After removing all the adapter cards from the system, you can remove the motherboard, which is usually held by several screws and can use plastic supports that raise the card of the metal chassis.
8 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
コメント 1 件
Hello Person I'm Matri65 I'm new here and I come to ask everyone to help me solve my problem on my pc. I have a tower when I click on it I activate the screen time on my pc and when I'm reading a review the mode screen turns off automatically and I always have to put the code on so I can see it. so my screen stays on in a short time can someone help me Thanks
