メインコンテンツにスキップ
Cuisinart Smart Stick CSB-75 Electrical Cord Replacement
必要な工具と部品
  1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: 手順 1、 3の画像 1 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: 手順 1、 3の画像 2 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: 手順 1、 3の画像 3
    • Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
    • After prying these off, the screws will be exposed.
  2. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 2、 2の画像 1 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 2、 2の画像 2
    • Remove three 13.3 mm Phillips PH#2 screws.
  3. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 3、 3の画像 1 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 3、 3の画像 2 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 3、 3の画像 3
    • Pry open Cuisinart using a plastic opening tool.
    • The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Make sure to pry open near the clips of the smart stick for easy opening.
  4. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 4、 3の画像 1 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 4、 3の画像 2 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 4、 3の画像 3
    • Unscrew the 4 screws on the inside.
    • Remove 2 13.3mm Phillips PH#2 screws.
    • Remove 2 17.5 mm Phillips PH#2 screws.
    • Unscrewing these screws will isolate the switch board.
  5. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 5、 3の画像 1 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 5、 3の画像 2 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 手順 5、 3の画像 3
    • Refer to these steps on Soldering to replace the electrical cord in the smart stick.
    • Be careful when soldering; it gets very hot.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jordan Robinson
メンバー登録日: 09/02/15
575 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 16-2, Wollert Fall 2015 USF Tampa, Team 16-2, Wollert Fall 2015人のメンバー
USFT-WOLLERT-F15S16G2
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 39
今までの合計 1,617
