はじめに
Use this guide to replace the "Chop" and "Grind" buttons located on the Cuisinart Mini-Prep DLC-2A.
必要な工具と部品
Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
Locate the Button Panel inside the blender.
Using your Phillips #1 Screwdriver, remove the two screws which hold the panel in place.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
