メインコンテンツにスキップ
Cuisinart Griddler GR- 4N Button Spring Replacement
必要な工具と部品
  1. Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: 手順 1、 2の画像 1 Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: 手順 1、 2の画像 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N Button Spring Replacement: 手順 2、 1の画像 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N Button Spring Replacement: 手順 3、 1の画像 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N Button Spring Replacement: 手順 4、 1の画像 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N Button Spring Replacement: 手順 5、 2の画像 1 Cuisinart Griddler GR- 4N Button Spring Replacement: 手順 5、 2の画像 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N Button Spring Replacement, Button Spring: 手順 6、 1の画像 1
    • Depress one of the gray tabs on the side of the housing.
  7. Cuisinart Griddler GR- 4N Button Spring Replacement: 手順 7、 1の画像 1
    • Pull out the black button and the spring will also come out within it.
  8. Cuisinart Griddler GR- 4N Button Spring Replacement: 手順 8、 1の画像 1
    • Pull out the spring, and insert the replacement spring making sure it is correctly aligned.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Laine Aro
メンバー登録日: 04/11/16
167 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 1-12, Maness Spring 2016 Cal Poly, Team 1-12, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S1G12
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 37
今までの合計 3,738
