メインコンテンツにスキップ
Cuisinart DFP-14BCN Switch Replacement
必要な工具と部品
  1. Cuisinart DFP-14BCN Switch Replacement, Bowl: 手順 1、 3の画像 1 Cuisinart DFP-14BCN Switch Replacement, Bowl: 手順 1、 3の画像 2 Cuisinart DFP-14BCN Switch Replacement, Bowl: 手順 1、 3の画像 3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Switch Replacement: 手順 2、 1の画像 1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Switch Replacement: 手順 3、 3の画像 1 Cuisinart DFP-14BCN Switch Replacement: 手順 3、 3の画像 2 Cuisinart DFP-14BCN Switch Replacement: 手順 3、 3の画像 3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Switch Replacement: 手順 4、 1の画像 1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Switch Replacement: 手順 5、 3の画像 1 Cuisinart DFP-14BCN Switch Replacement: 手順 5、 3の画像 2 Cuisinart DFP-14BCN Switch Replacement: 手順 5、 3の画像 3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Switch Replacement, Back Casing: 手順 6、 2の画像 1 Cuisinart DFP-14BCN Switch Replacement, Back Casing: 手順 6、 2の画像 2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Switch Replacement: 手順 7、 2の画像 1 Cuisinart DFP-14BCN Switch Replacement: 手順 7、 2の画像 2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Switch Replacement: 手順 8、 3の画像 1 Cuisinart DFP-14BCN Switch Replacement: 手順 8、 3の画像 2 Cuisinart DFP-14BCN Switch Replacement: 手順 8、 3の画像 3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Switch Replacement: 手順 9、 2の画像 1 Cuisinart DFP-14BCN Switch Replacement: 手順 9、 2の画像 2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Switch Replacement, Buttons: 手順 10、 3の画像 1 Cuisinart DFP-14BCN Switch Replacement, Buttons: 手順 10、 3の画像 2 Cuisinart DFP-14BCN Switch Replacement, Buttons: 手順 10、 3の画像 3
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Switch Replacement: 手順 11、 2の画像 1 Cuisinart DFP-14BCN Switch Replacement: 手順 11、 2の画像 2
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Switch Replacement: 手順 12、 1の画像 1
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Switch Replacement: 手順 13、 3の画像 1 Cuisinart DFP-14BCN Switch Replacement: 手順 13、 3の画像 2 Cuisinart DFP-14BCN Switch Replacement: 手順 13、 3の画像 3
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
  14. Cuisinart DFP-14BCN Switch Replacement, Switch: 手順 14、 2の画像 1 Cuisinart DFP-14BCN Switch Replacement, Switch: 手順 14、 2の画像 2
    • Desolder the white, black and red connections from the switch by using a soldering iron.
    • Refer to the soldering guide for extra help.
    • For reassembly, the new switch's connections will have to be soldered on.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Sonya Dick
メンバー登録日: 10/05/16
352 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-3, Livingston Fall 2016 Cal Poly, Team 10-3, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S10G3
3 メンバー
7のガイドは作成済み
コメント 1 件
You had me until the desoldering, maybe I’m just a wimp! Thanks anyway … good description!
dmdudek - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 1,490
