メインコンテンツにスキップ
Cuisinart DCC-1100 Hot Plate Replacement
必要な工具と部品
  1. Cuisinart DCC-1100 Hot Plate Replacement, Hot Plate: 手順 1、 1の画像 1
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Hot Plate Replacement: 手順 2、 1の画像 1
    • Remove the coffee pot and place the coffee maker upside down.
  3. Cuisinart DCC-1100 Hot Plate Replacement: 手順 3、 1の画像 1
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
  4. Cuisinart DCC-1100 Hot Plate Replacement: 手順 4、 1の画像 1
    • Remove the bottom panel.
  5. Cuisinart DCC-1100 Hot Plate Replacement: 手順 5、 1の画像 1
    • Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
  6. Cuisinart DCC-1100 Hot Plate Replacement: 手順 6、 1の画像 1
    • Remove the retaining bracket and allow it to hang off of the heating element.
  7. Cuisinart DCC-1100 Hot Plate Replacement: 手順 7、 1の画像 1
    • Remove the hot plate from the heating element.
    • New thermal paste should be applied at time of installation.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Josh Harvey
メンバー登録日: 01/25/18
886 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018人のメンバー
USFT-PASSMORE-S18S20G4
4 メンバー
7のガイドは作成済み
13 件のコメント
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Luciano Muzzatti - 返信
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Paulette Paglia - 返信
Josh
where do I buy the replacement hot plate?? I have the sis 15 coffeemaker and I have googled all over the place?? Thank u
linkev428 - 返信
Yes, where do you buy the part??
Kathy Johnston - 返信
Yes my question is where do you get the new hot plate? Any direction appreciated.
DougB - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 31
今までの合計 6,129
