メインコンテンツにスキップ
Cuisinart CPB-380 Power Cord Replacement
必要な工具と部品
  1. Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: 手順 1、 3の画像 1 Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: 手順 1、 3の画像 2 Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: 手順 1、 3の画像 3
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Power Cord Replacement: 手順 2、 2の画像 1 Cuisinart CPB-380 Power Cord Replacement: 手順 2、 2の画像 2
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Power Cord Replacement: 手順 3、 3の画像 1 Cuisinart CPB-380 Power Cord Replacement: 手順 3、 3の画像 2 Cuisinart CPB-380 Power Cord Replacement: 手順 3、 3の画像 3
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Power Cord Replacement: 手順 4、 3の画像 1 Cuisinart CPB-380 Power Cord Replacement: 手順 4、 3の画像 2 Cuisinart CPB-380 Power Cord Replacement: 手順 4、 3の画像 3
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Power Cord Replacement: 手順 5、 2の画像 1 Cuisinart CPB-380 Power Cord Replacement: 手順 5、 2の画像 2
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Power Cord Replacement, Power Cord: 手順 6、 2の画像 1 Cuisinart CPB-380 Power Cord Replacement, Power Cord: 手順 6、 2の画像 2
    • Remove the 2 black, yellow, and red wires from circuit board by push down on the tab to release and then pull up.
  7. Cuisinart CPB-380 Power Cord Replacement: 手順 7、 1の画像 1
    • Pinch perpendicular to the flat surface and pull out the black wire.
終わりに
作成者
2人の作成者と共同で作成されました。
Mary Harold
メンバー登録日: 09/24/18
88 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 143
