メインコンテンツにスキップ
Crown Range Hood AFG-AC/SS Light Bulb Replacement
必要な工具と部品
  1. Crown Range Hood AFG-AC/SS Light Bulb Replacement, Light Bulb: 手順 1、 1の画像 1
    • Check to make sure the the range hood is off.
    • To turn the range hood off, press the highlighted button.
    • The range hood should not emit any light or make any noise.
  2. Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 2、 2の画像 1 Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 2、 2の画像 2
    • Use the Phillips #00 to remove the single screw securing the lightbulb panel to the ceiling of the range.
    • Too prevent both of the items from falling, hold onto the screw and panel during removal.
  3. Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 3、 1の画像 1
    • Slide the lightbulb cover out from the recessed area under the hood.
  4. Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 4、 2の画像 1 Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 4、 2の画像 2
    • Twist the light bulb left to remove it from the range hood.
  5. Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 5、 1の画像 1
    • Use a cloth or a paper towel to clean the inside of the light bulb area.
    • Be sure to remove any debris or rust that might impair the installation of the new light bulb.
  6. Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 6、 1の画像 1
    • Guide the new lightbulb to the middle of the lightbulb base.
    • Install the new lightbulb with a twisting motion to the right.
    • Ensure the lightbulb is tightly secured onto the lightbulb base but don't overtighten.
  7. Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 7、 2の画像 1 Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 7、 2の画像 2
    • Place the screw back into the light bulb cover.
  8. Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 8、 1の画像 1
    • Set the light bulb cover back onto the light recess.
    • Use the Philips #00 screwdriver to tighten the single screw that holds the light bulb cover in place.
  9. Crown Range Hood AFG-AC/SS Light Bulb Replacement: 手順 9、 1の画像 1
    • Turn the light on to make sure your repair was successful!
ゴール
作成者
1人の作成者と共同作成されました。
Ken Cantago
メンバー登録日: 01/30/23
169 ポイント
1ガイドが承認済み
チーム
York University, Team M-7, Allen Winter 2023 York University, Team M-7, Allen Winter 2023人のメンバー
YORK-ALLEN-W23SMG7
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 36
今までの合計 225
