メインコンテンツにスキップ
Crosley CR8005A Belt Replacement
必要な工具と部品
  1. Crosley CR8005A Belt Replacement, Belt: 手順 1、 1の画像 1
    • Remove the slipmat and locate the small, round clip which holds the turntable platter to the turntable.
    • Insert the iFixit opening tool between the spindle and the clip and pry off the clip.
    • The clip does not need to be replaced and might already be missing.
  2. Crosley CR8005A Belt Replacement: 手順 2、 1の画像 1
    • After removing the clip, lift the turntable platter off the chrome spindle on the turntable base. The band connects the platter to the turntable base and will likely fall off in this process.
    • There will be some lubricant on the band and the metal prong on the turntable base. Leave this lubricant as is.
  3. Crosley CR8005A Belt Replacement: 手順 3、 1の画像 1
    • Turn the platter over so that you are looking at the underside.
    • Stretch the new band around the raised, internal circle and loop the band over the raised prong. This will create a teardrop shape with your new band.
    • Try not to over-stretch the new band or you will need to replace it too.
  4. Crosley CR8005A Belt Replacement: 手順 4、 1の画像 1
    • Turn the platter back over and place it on the spindle.
    • Spin the platter 2 times clockwise to unloop the band from the raised prong on the platter and to loop it around the raised prong on the turntable base. This allows the circular motion of the motor to spin the band and the turntable platter.
    • You may replace the round clip at this point though it is not important to the sound quality of the turntable.
終わりに
Now, spin some tunes and enjoy your improved sound!
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Ramie Bell
メンバー登録日: 10/30/19
249 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S2-G3, Kim Fall 2019 University of Memphis, Team S2-G3, Kim Fall 2019人のメンバー
UM-KIM-F19S2G3
4 メンバー
3のガイドは作成済み
コメント 1 件
what to do if you cannot lift up the platter in step 2.
Priyanka Baghaie - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 38
過去 30 日: 183
今までの合計 12,869
