はじめに
When everything is working as it should, the speaker produces nearly the same vibrations that the microphone originally recorded and encoded on a tape, CD or LP record.
必要な工具と部品
Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
ある他の人がこのガイドを完成しました。
コメント 1 件
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
