メインコンテンツにスキップ
Crosley 33301 Front Glass Replacement
必要な工具と部品
  1. Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 手順 1、 3の画像 1 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 手順 1、 3の画像 2 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 手順 1、 3の画像 3
    • Rotate Clock till the face/or front is pointing away from you.
    • Continue on by unscrewing the 5.5 millimeter screws with your hands.
    • Once all the screws are removed, take the circular back panel off and lay it down flat on a stable surface to put back on later.
  2. Crosley 33301 Front Glass Replacement: 手順 2、 2の画像 1 Crosley 33301 Front Glass Replacement: 手順 2、 2の画像 2
    • Unscrew the two remaining screws with a PH2 bit.
    • Do not be afraid to use additional force to remove these screws. Just be careful not to break the clock!
  3. Crosley 33301 Front Glass Replacement: 手順 3、 2の画像 1 Crosley 33301 Front Glass Replacement: 手順 3、 2の画像 2
    • Remove the front part of the clock from the back frame.
    • No major force is required. The back frame should slide right off.
  4. Crosley 33301 Front Glass Replacement: 手順 4、 2の画像 1 Crosley 33301 Front Glass Replacement: 手順 4、 2の画像 2
    • You will notice that there are three small indents on alternate sides.
    • You will see small slits where the indents can slide through.
    • Twist the center counter clockwise so that the face and the back are no longer connected.
  5. Crosley 33301 Front Glass Replacement: 手順 5、 2の画像 1 Crosley 33301 Front Glass Replacement: 手順 5、 2の画像 2
    • Replace the front of the clock with your new glass face protector and settle it on the frame.
    • The glass for this clock is 10cm in diameter. It would be best to use glass that fits this measurement!
  6. Crosley 33301 Front Glass Replacement: 手順 6、 3の画像 1 Crosley 33301 Front Glass Replacement: 手順 6、 3の画像 2 Crosley 33301 Front Glass Replacement: 手順 6、 3の画像 3
    • Apply the clock face back on the frame, then reverse your steps. Take a step back and admire your handiwork!
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Tenaya
メンバー登録日: 05/31/16
125 ポイント
1ガイドが承認済み
チーム
Central Coast New Tech High, Team 4-5, Rushing Spring 2016 Central Coast New Tech High, Team 4-5, Rushing Spring 2016人のメンバー
CCNTH-RUSHING-S16S4G5
2 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 69
今までの合計 2,452
