メインコンテンツにスキップ
Cricut Maker Roller Bar Replacement
必要な工具と部品
  1. Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: 手順 1、 3の画像 1 Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: 手順 1、 3の画像 2 Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: 手順 1、 3の画像 3
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Roller Bar Replacement: 手順 2、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 2、 2の画像 2
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Roller Bar Replacement: 手順 3、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 3、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 3、 3の画像 3
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Roller Bar Replacement: 手順 4、 1の画像 1
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
  5. Cricut Maker Roller Bar Replacement, Front Door Replacement: 手順 5、 2の画像 1 Cricut Maker Roller Bar Replacement, Front Door Replacement: 手順 5、 2の画像 2
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Roller Bar Replacement: 手順 6、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 6、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 6、 3の画像 3
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Roller Bar Replacement: 手順 7、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 7、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 7、 3の画像 3
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
  8. Cricut Maker Roller Bar Replacement: 手順 8、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 8、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 8、 3の画像 3
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
  9. Cricut Maker Roller Bar Replacement: 手順 9、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 9、 2の画像 2
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Roller Bar Replacement: 手順 10、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 10、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 10、 3の画像 3
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
  11. Cricut Maker Roller Bar Replacement: 手順 11、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 11、 2の画像 2
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
  12. Cricut Maker Roller Bar Replacement: 手順 12、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 12、 2の画像 2
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Roller Bar Replacement: 手順 13、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 13、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 13、 3の画像 3
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
  14. Cricut Maker Roller Bar Replacement: 手順 14、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 14、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 14、 3の画像 3
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
  15. Cricut Maker Roller Bar Replacement, Motor: 手順 15、 2の画像 1 Cricut Maker Roller Bar Replacement, Motor: 手順 15、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
  16. Cricut Maker Roller Bar Replacement: 手順 16、 1の画像 1
    • Remove the motor by pulling it from the device.
  17. Cricut Maker Roller Bar Replacement: 手順 17、 1の画像 1
    • Under the motor there is a white plastic gear. To remove it, gently pull it off the axle.
  18. Cricut Maker Roller Bar Replacement: 手順 18、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 18、 2の画像 2
    • Remove the washer from the top screw above the motor.
    • We found it was easier done by hand.
  19. Cricut Maker Roller Bar Replacement: 手順 19、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 19、 2の画像 2
    • Remove the two 5 mm screws from the remaining motor on the opposite side, using a Phillips #2 screwdriver.
  20. Cricut Maker Roller Bar Replacement: 手順 20、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 20、 2の画像 2
    • Twist and remove the motor from the machine.
    • Avoid touching the various tach disks on these motors.
  21. Cricut Maker Roller Bar Replacement, Belt: 手順 21、 3の画像 1 Cricut Maker Roller Bar Replacement, Belt: 手順 21、 3の画像 2 Cricut Maker Roller Bar Replacement, Belt: 手順 21、 3の画像 3
    • Remove the two 10 mm screws using a Phillips #2 screwdriver.
  22. Cricut Maker Roller Bar Replacement: 手順 22、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 22、 2の画像 2
    • Pull the belt holder towards you, and twist it sideways to slide it neatly into the same hole the belt is emerging from.
  23. Cricut Maker Roller Bar Replacement: 手順 23、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 23、 2の画像 2
    • Pull the bar containing the axel and metal attachment out to remove them.
    • This should free the remaining side of the belt.
  24. Cricut Maker Roller Bar Replacement: 手順 24、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 24、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the board on the main motor.
  25. Cricut Maker Roller Bar Replacement: 手順 25、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 25、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 25、 3の画像 3
    • Remove the electrical tape from the connecting cable on the backside of the main motor.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Pull the cable out.
  26. Cricut Maker Roller Bar Replacement: 手順 26、 3の画像 1 Cricut Maker Roller Bar Replacement: 手順 26、 3の画像 2 Cricut Maker Roller Bar Replacement: 手順 26、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the two 7 mm screws from the belt holder under the main motor.
    • Removing these two screws will cause the belt holder to detach.
    • Slip it through the hole in the main motor frame.
  27. Cricut Maker Roller Bar Replacement: 手順 27、 2の画像 1 Cricut Maker Roller Bar Replacement: 手順 27、 2の画像 2
    • Remove the washer (e-clip) securing the bar to the belt holder.
    • We found it is easiest to remove by hand.
    • To remove it, simply twist and pull upwards to free it.
    • Remove the bar from the belt holder and then remove the belt holder.
    • Slip the belt out of the machine.
  28. Cricut Maker Roller Bar Replacement, Roller Bar Replacement: 手順 28、 2の画像 1 Cricut Maker Roller Bar Replacement, Roller Bar Replacement: 手順 28、 2の画像 2
    • Pull the bar to the right of the machine, to free it from its placement.
  29. Cricut Maker Roller Bar Replacement: 手順 29、 1の画像 1
    • Slide the roller bar out to remove it from the machine.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Devyn White
メンバー登録日: 09/20/22
1,041 ポイント
5のガイドは作成済み
チーム
Austin Community College, Team 9-1, Watkins Fall 2022 Austin Community College, Team 9-1, Watkins Fall 2022人のメンバー
AUSTINCC-WATKINS-F22S9G1
3 メンバー
23のガイドは作成済み
4 件のコメント
I think there's a step missing between step 4 and 5. Took the lid off in 4 and in 5 we can already see the motor...
Jamie French - 返信
For Step #4, for some models, there's 7 silver screws you'll need to remove. You'll need a #1 driver to take them out from the ceiling of the cutting area. That allowed me to take the lid off.
A Regis - 返信
Do you have aline the gears when you put it back together that are on the left side for the small roller ?
Tim Norvill - 返信
Someone can tell me where we can get this gear?
Rachel Cadot - 返信
コメントを追加
統計データ:
過去 24時間: 32
過去 7 日: 167
過去 30 日: 690
今までの合計 14,759
