はじめに
The motherboard of the Cricut Maker device serves as the central control panel, governing the machine's operations. If you're encountering issues related to its proper functioning or the USB port, this guide is tailored to assist you effectively. Before proceeding with any repair steps, ensure the device is powered off and disconnected from the electrical outlet.
必要な工具と部品
To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
Remove the cover from the connecting joint and set it aside.
Using your hands or an opening tool, remove the four foot pads covering four screws.
Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
Pull the bar to the right of the machine, to free it from its placement.
Replacing the motherboard in your Cricut Maker can be a challenging yet rewarding task. By following the outlined steps carefully and using the appropriate tools, you can successfully complete the replacement process. Remember to prioritize safety by powering off the device and unplugging it before beginning any repair work. After installing the new motherboard, conduct thorough testing to ensure all functions are working correctly. If you encounter any difficulties or have concerns, seek guidance from the manufacturer or a professional technician for assistance.
4 の人々がこのガイドを完成させました。
5 件のコメント
So do you sell the motherboard or know where it buy one for cricut cxpl301
I too am looking for a replacement board. It was suggested to me that I could contact one of the pcb repair companies. For a fee, they will either check and repair your board or they will copy and print a new board and mail it back to you. You have to send in your board for them to check and copy though. So I guess reputation and reviews would be priority. It would suck to send our boards off and never receive a new one or the old one. :-/.
sooooo, theres no place to get parts? thats stupid...might as well just through it away then...
Bonjour pourriez vous nous dire où trouver la carte mère svp
