はじめに
In this guide, you will be able to remove the motherboard from a creative ZiiO and use a soldering iron while doing so.
必要な工具と部品
Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
Remove the copper plate covering the motherboard by desoldering the ten solder points.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
