メインコンテンツにスキップ
Creative Ziio 7" LCD Screen Replacement
必要な工具と部品
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: 手順 1、 3の画像 1 Creative Ziio 7" LCD Screen Replacement, Back Panel: 手順 1、 3の画像 2 Creative Ziio 7" LCD Screen Replacement, Back Panel: 手順 1、 3の画像 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: 手順 2、 1の画像 1
    • Remove the four 3mm Philips #00 screws around the large silver battery.
  3. Creative Ziio 7" LCD Screen Replacement: 手順 3、 1の画像 1
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
  4. Creative Ziio 7" LCD Screen Replacement: 手順 4、 3の画像 1 Creative Ziio 7" LCD Screen Replacement: 手順 4、 3の画像 2 Creative Ziio 7" LCD Screen Replacement: 手順 4、 3の画像 3
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
  5. Creative Ziio 7" LCD Screen Replacement: 手順 5、 1の画像 1
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
  6. Creative Ziio 7" LCD Screen Replacement: 手順 6、 1の画像 1
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
  7. Creative Ziio 7" LCD Screen Replacement: 手順 7、 2の画像 1 Creative Ziio 7" LCD Screen Replacement: 手順 7、 2の画像 2
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
  8. Creative Ziio 7" LCD Screen Replacement: 手順 8、 1の画像 1
    • Carefully remove the black LCD screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Kyle
メンバー登録日: 04/16/13
111 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S14G10
4 メンバー
13のガイドは作成済み
2 件のコメント
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - 返信
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,352
