メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Creative Ziio 7" LCD Screen Replacement
必要な工具と部品
    1. Creative Ziio 7" LCD Screen Replacement, Back Panel: 手順 1、 3の画像 1 Creative Ziio 7" LCD Screen Replacement, Back Panel: 手順 1、 3の画像 2 Creative Ziio 7" LCD Screen Replacement, Back Panel: 手順 1、 3の画像 3
      • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
      • The volume control button and the top power button may fall out during this step.
      FixBotに聞いてみる
      コメントを追加
    1. Creative Ziio 7" LCD Screen Replacement, LCD Screen: 手順 2、 1の画像 1
      • Remove the four 3mm Philips #00 screws around the large silver battery.
      FixBotに聞いてみる
      コメントを追加
    2. Creative Ziio 7" LCD Screen Replacement: 手順 3、 1の画像 1
      • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
      FixBotに聞いてみる
      コメントを追加
    3. Creative Ziio 7" LCD Screen Replacement: 手順 4、 3の画像 1 Creative Ziio 7" LCD Screen Replacement: 手順 4、 3の画像 2 Creative Ziio 7" LCD Screen Replacement: 手順 4、 3の画像 3
      この手順で使用する道具:
      • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
      • Carefully lift up the circuit board on the detached side.
      • There is another ribbon cable attached to the underside of the circuit board.
      • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
      • The circuit board is extremely delicate. Move carefully and don't rush on this step!
      FixBotに聞いてみる
      コメントを追加
    4. Creative Ziio 7" LCD Screen Replacement: 手順 5、 1の画像 1
      • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
      FixBotに聞いてみる
      コメントを追加
    5. Creative Ziio 7" LCD Screen Replacement: 手順 6、 1の画像 1
      • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
      • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
      FixBotに聞いてみる
      コメントを追加
    6. Creative Ziio 7" LCD Screen Replacement: 手順 7、 2の画像 1 Creative Ziio 7" LCD Screen Replacement: 手順 7、 2の画像 2
      • Carefully pry the thin, metal frame from around the LCD screen.
      • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
      FixBotに聞いてみる
      コメントを追加
    7. Creative Ziio 7" LCD Screen Replacement: 手順 8、 1の画像 1
      • Carefully remove the black LCD screen.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Kyle
メンバー登録日: 04/16/13
126 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S14G10
4 メンバー
15のガイドは作成済み
2件のガイドコメント
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - 返信 共有
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 31
今までの合計 1,779
