この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show you how to remove and install the keypad for your device. Use this guide if your buttons stop working because the keypad is broken.
必要な工具と部品
Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
もう少しです!
終わりに
