メインコンテンツにスキップ
Creative Zen Vision W Keypad Replacement
必要な工具と部品
  1. Creative Zen Vision W Keypad Replacement, Front Cover: 手順 1、 2の画像 1 Creative Zen Vision W Keypad Replacement, Front Cover: 手順 1、 2の画像 2
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W Keypad Replacement: 手順 2、 3の画像 1 Creative Zen Vision W Keypad Replacement: 手順 2、 3の画像 2 Creative Zen Vision W Keypad Replacement: 手順 2、 3の画像 3
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  3. Creative Zen Vision W Keypad Replacement, LCD Screen: 手順 3、 3の画像 1 Creative Zen Vision W Keypad Replacement, LCD Screen: 手順 3、 3の画像 2 Creative Zen Vision W Keypad Replacement, LCD Screen: 手順 3、 3の画像 3
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  4. Creative Zen Vision W Keypad Replacement: 手順 4、 1の画像 1
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  5. Creative Zen Vision W Keypad Replacement: 手順 5、 1の画像 1
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  6. Creative Zen Vision W Keypad Replacement: 手順 6、 3の画像 1 Creative Zen Vision W Keypad Replacement: 手順 6、 3の画像 2 Creative Zen Vision W Keypad Replacement: 手順 6、 3の画像 3
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
  7. Creative Zen Vision W Keypad Replacement, Keypad: 手順 7、 1の画像 1
    • Peel the orange sticker off of the motherboard.
  8. Creative Zen Vision W Keypad Replacement: 手順 8、 2の画像 1 Creative Zen Vision W Keypad Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Lift the keypad from the left side and use tweezers to slide it out to the left.
  9. Creative Zen Vision W Keypad Replacement: 手順 9、 2の画像 1 Creative Zen Vision W Keypad Replacement: 手順 9、 2の画像 2
    • Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
    • Remove the ribbon cable from the keypad.
終わりに
作成者
7人の作成者と共同で作成されました。
Tim Wilson
メンバー登録日: 04/11/13
143 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 427
