この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show you how to remove the front cover of your device. Use this guide to gain access to the button pad and LCD screen.
必要な工具と部品
Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
When the cover has been lifted off the screen, use your hands to remove it from the device.
The button pad may fall off when the cover is removed.
もう少しです!
終わりに
