メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will show you how to remove the front cover of your device. Use this guide to gain access to the button pad and LCD screen.
パーツ
パーツは指定されていません。
  1. Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
    • Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
  2. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  3. Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
    • Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
  4. Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen. When the cover has been lifted off the screen, use your hands to remove it from the device. The button pad may fall off when the cover is removed.
    • Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
    • When the cover has been lifted off the screen, use your hands to remove it from the device.
    • The button pad may fall off when the cover is removed.
終わりに
Gabriele Pregadio
メンバー登録日: 2013年04月17日
1 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G2
4 メンバー
8のガイドは作成済み
コメント1件
Fantastic but does anyone know where I can get this part?
VegetaFlex4Fitness - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 287
