メインコンテンツにスキップ
Creative Zen Vision W Battery Replacement
必要な工具と部品
  1. Creative Zen Vision W Battery Replacement, Battery Removal: 手順 1、 3の画像 1 Creative Zen Vision W Battery Replacement, Battery Removal: 手順 1、 3の画像 2 Creative Zen Vision W Battery Replacement, Battery Removal: 手順 1、 3の画像 3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Creative Zen Vision W Battery Replacement, Battery: 手順 2、 2の画像 1 Creative Zen Vision W Battery Replacement, Battery: 手順 2、 2の画像 2
    • Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
    • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
    I am having trouble finding the replacement battery for my Zen W.
    wayne clements - 返信
  3. Creative Zen Vision W Battery Replacement: 手順 3、 3の画像 1 Creative Zen Vision W Battery Replacement: 手順 3、 3の画像 2 Creative Zen Vision W Battery Replacement: 手順 3、 3の画像 3
    • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
終わりに
Follow these instructions in reverse order to reassemble your device.
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Tim Wilson
メンバー登録日: 04/11/13
143 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G2
4 メンバー
8のガイドは作成済み
3 件のコメント
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - 返信
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - 返信
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 35
今までの合計 5,712
