必要な工具と部品
Slide down the eject button.
Pull out the old SmartMedia Card.
Insert the new SmartMedia Card.
The notched corner of the SmartMedia card should go in the top left corner.
Using a Phillips #00 Screwdriver, remove the two 7.5 mm screws located on the left and right side of the back cover, respectively.
Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located in the bottom corners of the battery compartment.
Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located on the left and right edges of the circuit board.
Using a pair of tweezers, gently lift and peel back the thin copper film covering the headphone jack.
Only peel back the film enough to expose the headphone jack.
