はじめに
Use this guide to create a buttonhole with your sewing machine. We’re using a Bernina 830, but the process should be similar for all sewing machines with a mechanical buttonhole dial. Since every sewing machine is different, refer to your sewing machine’s owner’s manual for specific information. In this guide we’re using contrasting thread for visibility. When it comes time for your actual project, you’ll want to use thread that matches the color of your fabric.
必要な工具と部品
Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual.
Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
Set your buttonhole dial to five.
This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
7 の人々がこのガイドを完成させました。
2件のガイドコメント
The same thing happened to me when I first tried this too, Holly.
I discovered that I was over-stitching position 2.
Now, I do a maximum 3 stitches only, before I go on to position 3 and everything works beautifully. I don’t have to turn the fabric around - position 3 stitches in reverse, and I finish off with a couple of stitches in position 2, to top off the button-hole.
I hope this helps!
