はじめに
This handy shortcut will allow you to pair your AirPods in just one click, rather than going to Bluetooth>YourAirPodsNameHere>Connect. In the long run it could save you up to 18 min each year!
Open AppleScript or Script Editor, whichever comes up for you.
Go to Finder > Applications > Utilities > Script Editor/AppleScript
At the popup for Script Editor click New Document at the bottom left corner. Then Copy and Paste the code into Script Editor/AppleScript that I have provided down below in the link.
Next, we have to configure the Script. First, have a look at my image and select the group of text I circled. Replace that text with the name of your AirPods. Keep the quotation marks around the name or the Script will not function.
For example, my AirPods are named "Jet the Hawk".
If your AirPods name in Bluetooth Preferences contains an apostrophe in it, double check that it appears the same way it does in your script. For example, the default name given for my AirPods would be “Jimmy’s AirPods”. In the script it will appear as “Jimmy's AirPods”. If you look closely they both have different apostrophes. One is curved, ‘, and one is straight, '. Renaming the device in either Bluetooth Preferences or in the Script Editor will fix the issue with apostrophes.
Now press Command + S at the same time to save the file. Name it Connect to AirPods and save it in Application file format. Save it to your desktop.
Go to System Preferences > Security & Privacy > Accessibility > Privacy
Click the lock and enter your admin username and password.
Check the box to the left of Connect to AirPods
Download Image2Icon from the Mac App Store. It is completely free, no worries.
Find a good image to use as your App icon, preferably a .png icon.
Now, open Image2Icon and drag and drop the image you want as the icon into the Image2Icon window.
Drag the Connect to AirPods Application into the Image2Icon window
Enjoy your new shortcut!
10 の人々がこのガイドを完成させました。
2 件のコメント
Thanks for this guide Aaron! After setting up Siri Shortcuts to do this on my iOS devices, I really wanted something comparable on my Mac and this worked perfectly. Referring to Step 3, I really wanted to keep that apostrophe so after some fiddling around, I realized that the apostrophe in the name generated by default for my AirPods was different than the one I was writing in the script. The default name includes a ‘ while in the script editor my keyboard was typing out a '. If you look closely they are different characters with ASCII codes 8216 and 39 respectively. I simply renamed my AirPods in Bluetooth Preferences to match what was in my script and it worked like a charm! Hopefully this works for anybody else who tries this and wants to keep their apostrophe.
Thank you! It works perfectly. One question: Siri won’t open this App, instead gives error: “I can’t do that”. I put this app into Applications.
