メインコンテンツにスキップ
Creality Ender 3 V2 Extruder Nozzle Replacement
必要な工具と部品
  1. Creality Ender 3 V2 Extruder Nozzle Replacement, Extruder Nozzle: 手順 1、 1の画像 1
    • Move the extruder carriage to the center of the machine.
  2. Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 2、 1の画像 1
    • Use a 2 mm Allen wrench to remove the two screws located on the back of the extruder shroud.
  3. Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 3、 1の画像 1
    • Carefully remove the shroud by pulling it away from the hot end of the 3D printer.
  4. Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 4、 3の画像 1 Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 4、 3の画像 2 Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 4、 3の画像 3
    • Remove the silicon sleeve around the heat block.
    • Before removing the nozzle, you must bring the printer up to operating temperature in order to remove the leftover filament from the extruder.
  5. Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 5、 2の画像 1 Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 5、 2の画像 2
    • Once the excess filament has been removed, loosen the nozzle by a quarter turn using the wrench provided, then either power off or cool down the printer.
    • Do not attempt to fully remove the nozzle while the printer is at operating temperature. Allow the nozzle to fully cool before removal.
  6. Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 6、 3の画像 1 Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 6、 3の画像 2 Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 6、 3の画像 3
    • Before removing the nozzle check the temperature by bringing the back of your hand near the nozzle; do not touch it. If you feel any heat on the back of your hand, then wait another 10-15 minutes before removing the nozzle.
    • If the nozzle is fully cooled, remove the nozzle.
  7. Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 7、 2の画像 1 Creality Ender 3 V2 Extruder Nozzle Replacement: 手順 7、 2の画像 2
    • Screw on the new nozzle into the heat block with your wrench.
    • To fully tighten the nozzle, bring the printer back to operating temperature and do a final tightening of the nozzle.
    • Printer must be at operating temperature when fully tightening in order to prevent leaks in the future.
終わりに
Print away!
7 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Marc-Anthony Cardoso
メンバー登録日: 03/24/21
235 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S2-G3, Riel Spring 2021 UMass Dartmouth, Team S2-G3, Riel Spring 2021人のメンバー
UMASSD-RIEL-S21S2G3
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 116
過去 30 日: 622
今までの合計 17,540
