メインコンテンツにスキップ
Crayola Crayon Maker White Plastic Arm Replacement
必要な工具と部品
  1. Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: 手順 1、 3の画像 1 Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: 手順 1、 3の画像 2 Crayola Crayon Maker White Plastic Arm Replacement, Take out the melting tray that is out of place.: 手順 1、 3の画像 3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: 手順 2、 3の画像 1 Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: 手順 2、 3の画像 2 Crayola Crayon Maker White Plastic Arm Replacement, Remove the metal melting tray.: 手順 2、 3の画像 3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: 手順 3、 3の画像 1 Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: 手順 3、 3の画像 2 Crayola Crayon Maker White Plastic Arm Replacement, Remove the light bulb: 手順 3、 3の画像 3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
  4. Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: 手順 4、 3の画像 1 Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: 手順 4、 3の画像 2 Crayola Crayon Maker White Plastic Arm Replacement, Remove the green base from the crayon maker: 手順 4、 3の画像 3
    • Flip the crayon maker.
    • Remove six screws (2 cm in length) with a spanner.
    • Remove the green base plate and set it aside.
  5. Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: 手順 5、 3の画像 1 Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: 手順 5、 3の画像 2 Crayola Crayon Maker White Plastic Arm Replacement, Locate the Plastic arm: 手順 5、 3の画像 3
    • Locate the clear plastic arm inside the control box.
  6. Crayola Crayon Maker White Plastic Arm Replacement, Adjust/Replace the Plastic Arm: 手順 6、 2の画像 1 Crayola Crayon Maker White Plastic Arm Replacement, Adjust/Replace the Plastic Arm: 手順 6、 2の画像 2
    • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
    • If the plastic arm is broken, contact Crayola for replacement parts.
  7. Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: 手順 7、 3の画像 1 Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: 手順 7、 3の画像 2 Crayola Crayon Maker White Plastic Arm Replacement, Locate the clear plastic box: 手順 7、 3の画像 3
    • Remove the green base from the crayon maker and set aside.
    • Locate the clear box.
  8. Crayola Crayon Maker White Plastic Arm Replacement, Remove clear box.: 手順 8、 2の画像 1 Crayola Crayon Maker White Plastic Arm Replacement, Remove clear box.: 手順 8、 2の画像 2
    • There are four screws (circled in red) that need to be removed with a Phillips #00 Precision screwdriver.
  9. Crayola Crayon Maker White Plastic Arm Replacement, Open Clear Plastic Box: 手順 9、 1の画像 1
    • Remove five screws (1.5 cm in length) using a Phillips #00 Precision screwdriver and open the clear plastic box.
  10. Crayola Crayon Maker White Plastic Arm Replacement, Check placement of white plastic arm.: 手順 10、 1の画像 1
    • The plastic arm should be positioned as shown in the figure. Adjust the arm's position if necessary.
    • If the plastic arm is broken, contact Crayola for a replacement arm.
終わりに
ある他の人がこのガイドを完成しました。
作成者
13人の作成者と共同で作成されました。
Melissa
メンバー登録日: 10/10/14
210 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 734
