はじめに
In order for the Crayola Crayon Maker to melt crayon pieces and create new whole crayons, the light bulb needs to be in good working order. To replace a burned out bulb, all that is needed is a small Phillips screwdriver and a colorless 60-watt candelabra light bulb with a small base.
  1. Press the green arm away from the melting tray. Remove the melting tray. Pop the metal arms out of the green pivot support. Pop the metal arms out of the green pivot support.
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  3. Remove the 2 screws (.75cm in length) currently securing the metal melting tray  with a Phillips #2 screwdriver. Remove the 2 screws (.75cm in length) currently securing the metal melting tray  with a Phillips #2 screwdriver. Remove the 2 screws (.75cm in length) currently securing the metal melting tray  with a Phillips #2 screwdriver.
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  4. The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb. The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb. The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
ゴール
ある他の人がこのガイドを完成しました。
Heidi Clarke
メンバー登録日: 2014年09月21日
222 ポイント
2のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 5
過去 7 日: 8
過去 30 日: 27
今までの合計 3,885
